Still can't get my clutch to work...
Old 03-13-2009 | 08:45 PM
VLANDER005's Avatar
Default Still can't get my clutch to work...
So I used the mightyvac to remove the air from my clutch system and I still can't get the car to go into gear. I installed a used mcleod clutch with 5k on it from a buddy of mine with a new gm master (with drill mod), slave, pilot & t/o bearing. I bled the system with a buddy manually w/o the mighty vac first and the car will not go into gear 90% of the time. Nor will it shift easily if it happens to go into gear. HELP! SPRING IS JUST AROUND THE CORNER!
Old 03-15-2009 | 09:17 PM
wrencher's Avatar
wrencher
Is that a twin disc set-up? How does the pedal feel?
