How Often Does a Slave Cylinder Need to be Changed?
Old Mar 18, 2009 | 06:06 PM
bluebird71's Avatar
Default How Often Does a Slave Cylinder Need to be Changed?
I am getting a new Textralia Exo-Skel twin disc put in to replace my blown out Spec 3. Someone suggested that I should go ahead and put in a fresh slave cylinder while I was in there. My current slave cylinder has about 5k miles on it. Is is really necessary to change this right now too or am I good to go ahead and reuse the same one? My pedal still feels really firm, even with the slipping clutch.
Old Mar 18, 2009 | 06:43 PM
TheLS1Kid's Avatar
If you can't do the work yourself then I'd replace it just to be sure. You don't want to have to pay someone to drop the tranny again just to replace the slave.
But if you want to take the chance then I'd say your definitely ok with only 5k.
Old Mar 18, 2009 | 07:16 PM
TheBlueKnight's Avatar
I just changed my slave cylinder last week. If I had to do the clutch in the next 5,000miles I would'nt change the slave, do what your most comfortable with though. My car has 75,000 miles on it so the original slave lasted a while.
Old Mar 18, 2009 | 09:31 PM
RARON455's Avatar
My original slave had 97k miles on it, and was working fine when i replaced the clutch, I swapped it just to be safe. With the low miles you have on it I would not even worry about it.
