Need help removing line from slave
Old Mar 28, 2009 | 06:24 PM
NJNETSFAN's Avatar
Default Need help removing line from slave
I'm in the middle of installing my tick master and I can't get the line disconnected from the slave cylinder. Any tips. I've played with the white tab pushing it in and everything. I just can't get it off. Here is a picture of what's going on....
Old Mar 28, 2009 | 07:11 PM
mrhzk35404's Avatar
Did you try using two small flat head screw drivers?
Old Mar 28, 2009 | 08:23 PM
BADD SS's Avatar
Besides a disconnect tool, a pair of dykes works fairly well, clost them against the steel fitting, push plastic in with them...
Old Mar 28, 2009 | 08:46 PM
slayerized6's Avatar
+1. it took a speed shop nearly 2 hours to remove the line from my car. 2 screwdrivers is what did the trick
Old Mar 28, 2009 | 10:26 PM
NJNETSFAN's Avatar
After I posted, I went back under the car and tried a screw driver. I was able to get it off then. The tick master is in the car and now I just need to bleed the system and adjust the peddle.
Old Mar 28, 2009 | 11:59 PM
camscam02's Avatar
those disconnects are such a pain in the ***...
Old Mar 29, 2009 | 08:22 AM
HavATampa's Avatar
Next time, do it right and use one of the fuel line disconnect tools, #5 size fits perfect.
Old Mar 29, 2009 | 10:42 AM
NJNETSFAN's Avatar
Hopefully there wont be a next time with this new master
