new clutch no work
new clutch no work
I just finished my install of my new monster stage 3 clutch, pilot, throwout, slave, tick mc w/ bleeder, and car wont go into gear. Goes in fine when car is off, but will not go into any gear when on. If i try to start car in gear it inches forward with the pedal down. I bled it pretty good and it seems like there is no air in the system. Clutch pedal pressure is good. I noticed that when i tried to put the car in gear with car on, it did not want to inch forward like it did before install, just rolled backward like it was in neutral. Any suggestions? As far as i know everything was installed properly and to tq spec. Maybe i forgot something that you guys may know.
I just did the same setup as you got. You might want to check your adjustment on your master cylinder. But what do I know I have spent a whole lot of money on the tranny and supporting parts and I am having all kinds of trouble out of mine too. Maybe someone could help the both of us
