tranny whines like a rear end....
Its not the pilot bearing . That makes noise in between shifts . If its a bearing , which I doubt , it would have to be the output shaft bearing , once again which I doubt .
I would double verify that it is making noise in 4th gear .
you have a built trans right? Is it a Viper shaft conversion? My Viper shafted tranny whines a little bit too after being "broken in" in two cars over the last couple years
How are you so sure it's the transmission? I would second that it's most likely your rear. The noise transfer almost always makes it sound like the rear whine is coming from the transmission. Mine is EXACTLY the same way. Stick anyone in my car who doesn't know about the whine you experience from these rears and they'd probably insist that my transmission is about the explode. It did it ever since I got the rear on the stock trans, with the new transmission, and still does it exactly the same after I just rebuilt my MN12 transmission about two weeks ago.
It also only does it at certain speeds and in certain gears. It's much louder cruising in fifth at XX mph than in, say, second or third cruising at XX mph. It's all about harmonics.
All that said, I am curious as to how you know it's coming from the trans.
