Clutch pedel loose
So I was driving, pushed the clutch in to shift, then I heard a sound like something came off the clutch pedal. The pedal is now looser than normal when not using it. I can wiggle it side to side and in and out a tiny bit. Pressing it down to use it and shifting seems normal. It sounded like maybe a screw or bracket rattled loose and fell off. Does anybody have any guess of what it could be or if it could be a problem? Thanks in advanced.
Where the master cylinder rod connects to your clutch pedal it is held by a pin. That pin may have came off. Get under your dash on the driver's side with a flash light and take a look under there. I think you'll see it will make sense how it works and you'll be able to tell what is wrong.
