TICK performance master cylinder **installed**
Old 04-03-2009 | 12:34 PM
SMOKNSS's Avatar
NICE!! I really need to hurry up and order mine before we put the engine in. Been so long cant even remember how good it feels to shift on the floor.
Old 04-04-2009 | 09:08 AM
alharbi's Avatar
Originally Posted by bearcatt
I see, that makes sense.
I looked at your other videos racing the Z06 and Nissan GTR.
That's one mean machine you have there.
What clutch are you running ?
thanks buddy
actually i'm runing spec clutch stage 3+
Old 04-04-2009 | 08:46 PM
wht01ws6ta's Avatar
I should have bought the Tick master when they had the sale going on
Old 04-05-2009 | 12:53 AM
bearcatt's Avatar
I just installed my Tick m/c today with an LS7 clutch today... WOW! what a big difference in shifting smoothness and disengagement! That Tick m/c pushes way more fluid than the stocker. I could see that clearly when bench bleeding it.
Old 04-05-2009 | 02:48 AM
ZMONSTER!'s Avatar
Anybody have a write up or advice on how to adjust this thing? I just got the tranny back in (new slave) and Ill be driving it tomorrow.
Old 04-05-2009 | 02:15 PM
bearcatt's Avatar
I thought the instructions were a bit ambiguous. Tick's instructions are trying to tell you not to over lengthen the adjustment rod to much as you may damage your clutch pressure plate fingers from over extension.
This Tick m/c pushes alot more fluid than the stocker. The stocker is a joke compared to the Tick m/c.
Basically I lengthend the adjustment rod just long enough to where the shifts weren't knotchy and the clutch would disengage much better. Thus it brought my clutch peddle higher off the floor.
Every car is different. I think you sort of have to dial in the settings abit.
This Tick m/c made my new LS7 work like it should.
Perhaps Joey from Tick or someone else can give some insight.
Old 04-06-2009 | 07:09 AM
alharbi's Avatar
what you waiting for .... come on , post some vids. and let's see how it's work with you
Old 04-06-2009 | 11:10 AM
lt1camaro95's Avatar
That would be nice. How is the fluid amount being pushed adjustable? I thought that was the whole point of this Master. If its only the rod that is adjustable then what is the point of and adjustable stocker like a RAM?
Old 04-06-2009 | 12:02 PM
Jonathan@Tick's Avatar
LS1TECH Sponsor
To adjust it, simply legnthen the rod till the car will go into gear from a stop easily. Then take it out, beat on it and fine tune the adjustment until the car will shift smoothly at high rpms. The longer you adjust the rod, the more fluid you will push therefore the more dissengagement you'd achieve. This is all possible because the bore of the cylinder is larger than factory. Once everything is adjusted properly, the pedal may not even be out as far as the factory pedal....
Old 04-06-2009 | 12:52 PM
bearcatt's Avatar
Haha! You're the man alharbi. I'm not pushing all the power you are.
Your car is a beast !
My videos wouldn't be as interesting. I have to do more work to my bird.
I'll see about posting some videos in the near future.
Old 04-06-2009 | 01:00 PM
bearcatt's Avatar
The more leverage or throw you have on the peddle, the more hydraulic fluid the Tick m/c will push. The adjustable Ram is not even comparable. The Tick m/c works without a doubt.
That was a good explanation Jonathan from Tick posted.
Old 04-06-2009 | 03:29 PM
  #32
ZMONSTER!'s Avatar
Just got mine installed and running yesterday. Holy lord it feels like a different car. Half the pedal travel from before and twice as stiff.
Question for yall how are you guys tightening down the locking nuts on either side of the adjusting rod? I cant get my hands up there even with the kick panels removed!
Old 04-06-2009 | 06:35 PM
  #33
bearcatt's Avatar
I snugged the nut near the peddle first and then snugged the rod end last.
( Not to tight just snug ) As the clutch wears you can re-adjust your
Tick m/c.
I know it's a tight fit underneath there.
Old 04-10-2009 | 11:20 PM
  #34
bluebird71's Avatar
I just got my car back from having the Tick MC and Textralia twin-disc put in. MAAAAN! What a huge difference it made. If feels like a totally different car now. It fully engages about 25% off the floor and the engagement point is short and tight as hell. I killed the car a few times right when I first picked it up cause I wasn't used to it yet, lol. A few minutes into driving it though and the car and I became closely acquainted once again. I can shift so much faster than before now too. I won't power shifting just yet since the clutch hasn't been fully broken in, but as soon as it is, I have a feeling my 10 bolt will be cursing my name.
Old 04-11-2009 | 01:53 PM
  #35
RsSean's Avatar
Hell yeah I need to order a new one for my other car.
Old 04-12-2009 | 01:24 AM
  #36
2002_Z28_Six_Speed's Avatar
Hello guys,
How much are these?
Thanks.
Old 04-12-2009 | 04:48 AM
  #37
Moonder's Avatar
Nice, i think i am going to order one this week
Old 04-12-2009 | 05:42 AM
  #38
BAMF's Avatar
I love powershifting, but I havent been doing it for a few years as my stock trans and master have been messed up, I'll be doin it again this year though
Old 04-12-2009 | 10:03 AM
  #39
INTENESS's Avatar
This is by far the best mod you can do if you have a 6spd car,This tick performance master is awsome performs like it says.
Old 04-12-2009 | 04:50 PM
  #40
jerflash's Avatar
i just did mine and the install was cake...much easier then i thought the old was out and the new was in in 2 hours about and that includes bleeding also...but my spec is pretty much done now and im going to need one of those monsters ;-)
