Clutch pedal too firm?
I have a 1968 firebird with a LS1 and T56 swap. I installed a new LS7 clutch and a wilwood master with 7/8 bore. The problem is it takes a ton of pressure to actuate the clutch. Also when I try to slowly let off the clutch to get going it snaps back with pressure. Its very hard to control. Will this get better once I drive it more? I have only drove it about half a block... Please help!
