monster Clutch disc install??
I just want to make sure that i install this correctly. Its a monster stage 3, and i'm wondering which side goes to the fly and which to the trans? The side where the springs are more visible to the eye (no black covering) Goes to the flywheel side , and the side with the Black covering over the springs goes to the trans side. Is this correct?
Sounds correct, but can you post a pic of a side, and i can tell you for sure if it is.
I logged on to Monster to see the pic of teh disc, and how you are describing it, is right. Good to go.
It will only go one way. Try both and you will see. The black part with the springs inside goes toward the trans. If you put this to the inside, the springs will hit the bolt heads. I learned this today also. We are installing the Monster Stage 3 right now also. We must just be a little ahead of you.
We are trying to get to the master cylinder and figure out how to install the new braided line. Slave cylinder was fun too.
