Bleeding clutch, need fast help!
Also, now that we've pulled that transmission back apart to get to the slave to bleed it easier, the slave started leaking around the inside where the shaft goes in...
Did we F*ck up the slave now?
Basically we were bleeding it, then heard a pop (air/fulid releasing) and now it leaks when we put the clutch to the floor
Basically we were bleeding it, then heard a pop (air/fluid releasing) and now it leaks when we put the clutch to the floor
I'm sorry, I meant bench bleed.
You should be able to bleed the slave with the tranny installed.
Just use a 7/16" socket with a ratchet. If you open the beeder, it will leak from the bell housing, that's normal.
The problem happened the first time that we actually got some pressure back in the clutch pedal with the slave out. Once i pushed it in i think it blew the end of the slave off (just a little bit) past the seal and thats when the leaking started. So would that have ruined the slave?
When you reinstall the trans and new slave, crack open the slave bleeder when re-installing the trans.
This way you won't hurt the slave and it will make it easier to install the trans.
Once everything is reinstalled, Just make sure to close the bleeder before you re-connect the master cylinder's hydraulic line.
Edit: Here's a link that might be helpful.
http://home.comcast.net/~buschman_00...utchbleed.html
Also sounds like your doing the old hold peddle down,crack bleeder which is the wrong way too.Crack bleeder,push peddle down,close bleeder is the correct way.
What exactly would that accomplish?
Open bleed screw, clutch pedal to the floor, close bleeder screw, pedal all the way up. Rinse repeat, took me about 30 mins and a pint of brake fluid to get it perfect.
Only downside is, I don't have any paint left on the trans tunnel on a spot about 10 x 10 inches from brake fluid getting on my gloves and rubbing the paint off. I'm not worried about it since its under the car, but I am going to get some NBM spray paint and cover it back up.
Of course I only stated it as a GM service manual fact. No tube from bleeder screw is entirely up to you guys. (Yes I will use one to route the fluid away from the bellhousing)
