Difficulty level of installing slave cylinder?
Old Apr 19, 2009 | 10:53 PM
landonew's Avatar
Originally Posted by 7camaro7
How hard is it to lift the tranny back up and get the bolts started with only floor jacks? I can bench press maybe 170-180lbs, but I need both hands to do it. Putting the bolts back in would be pretty tough!
It is not difficult if you have two people and patience. We considered benching it up their (I can bench well over 250), but it is just easier to use the two jack method as noted in the video above.
One hard part was getting the input shaft to line up correctly.
Old Apr 19, 2009 | 10:54 PM
landonew's Avatar
Originally Posted by slayerized6
the rear end has to be loaded. Either place jackstands under the rear or have the wheels on ramps. should make next time a lot easier
Thanks. Will try that next time.
Old Apr 19, 2009 | 11:07 PM
slayerized6's Avatar
$50 harbor freight trans jack f.t.w.
Old Apr 19, 2009 | 11:23 PM
TheLS1Kid's Avatar
I can bench 265lb, a t56 weighs nowhere close to that and it is still a pain in the *** to bench press just because of its shape and dimensions. It can be done, but its much easier if you have someone lift the front and someone else to lift the rear. That way you don't have to kill yourself. Good luck.
Old Apr 20, 2009 | 12:07 AM
landonew's Avatar
UGGGG!!!
Oh well, Guess I can put that $50 towards a shortblock
Old Apr 20, 2009 | 04:01 PM
landonew's Avatar
Well, the slave is installed.
Still sticks at high RPM shifts. The hydrolics are brand new. The clutch has less than 2000 miles on it. I am really frusterated at this point.
Old Apr 20, 2009 | 05:55 PM
TheLS1Kid's Avatar
Slave and master are new?
Try doing the drill mod.
Old Apr 20, 2009 | 06:39 PM
landonew's Avatar
Been there and done that. I think I am just going to put a TH400 or possibly a powerglide in it.
Old Apr 23, 2009 | 01:27 PM
TheBlueKnight's Avatar
Sorry to hear it still sticks at high rpm. Mine did too after I put in the brand new master and slave. Turns out I didn't bleed it good enough. I bled it again with my brother and now its pretty damn good. Before I bled it a second time it would be rough to get into third and then I'd be locked out of fourth on a WOT run.
Old Apr 23, 2009 | 02:26 PM
Bad Blue WS6's Avatar
i dont think im bleeding correctly,,,,,does someone have a good thread, etc on it, im searching now, but thought id ask....
Old Apr 23, 2009 | 04:11 PM
found it, guess i just needed to read the stickies...
What is the bleeding process?
1. Top off master with fluid
2. Pump a few times and hold pedal down.
3. Crack bleeder open while holding pedal down.
4. Close bleeder when fluid stops squirting out.
5. Release pedal and pump a few times.
6. Repeat steps 1-5 until pedal has full pressure.
It takes a while to get the pedal to build pressure if the system was dry, it took me like 30 minutes to bleed it all the way.
Old Apr 23, 2009 | 06:56 PM
  #32
remember to keep topping off the slave every two times you crack the bleeder. If you keep pumping it and crackin the bleeder and don't keep the resavior from going empty its gonna suck in air and you'll have to start all over!
Old Apr 24, 2009 | 08:27 AM
  #33
And by that you mean filling the lil canister in the engine bay by the fire wall, right? So really, without a remote type bleeder or hole in the floorboard, you almost need 3 people total,,one in the dr seat to pump, one under the car to crack the bleeder, and another in the engine bay doing the topping off and making sure no brake fluid is getting on the paint ...:
also,, do i leave the li lblack rubber thing out, and the lid off (engine bay canister) though out the entire process?
Old Apr 24, 2009 | 11:21 AM
  #34
Yes, the little canister in the engine bay by the firewall. Yeah, optimally you would have three people. Because it was me and my wife, I went under the car and would yell, "OK, PUMP THE CLUTCH!" She'd start pumpin away and after about 10 vigorous pumps I'd Yell "ALRIGHT, HOLD THE CLUTCH PEDAL IN!" I'd crack the bleeder a bit with my socket and ratchet for a few seconds, then pull down the ratchet, turn the little dial on the back of the ratchet to tighten, then take forever to put it back up there and find the bleeder and get it back on, then tighten it and yell, "OK, YOU CAN LET THE CLUTCH UP!"
After doing that twice I'd come out from under the car, open up the cap from the canister in the engine bay by the fire wall, and see that if I did it once more without filling it, it would be empty and would suck in air so I needed to fill it. I used a funnel to fill it so I'd have less of a chance to spill on paint . Then I put the cap back on, other wise the fluid will shoot out if you don't put the cap back on, (Its a sealed system). Then I'd get back under the car and start Yellin again. I did all this over and over again. Probably ended up crackin the bleeder like 10 times before I said, "screw it, I'm gonna go try it" and it worked!
Old Apr 24, 2009 | 11:50 AM
  #35
thanx man, you've been a huge help.
  #36
or you can get a mityvac........saves you time plus you got a cool new tool
