double cluthing
double cluthing
Just curious but i always double cluth when i down shift. Guess its just a habit from driving our 10sp truck at work. just wondering if anyone else does that when they downshift to run hard
double cluthing is when you rev the engine to match the transmission speed. It takes a little while to get used to because you have to learn your cars engine speed to wheel speed for the particular gear your are in. Even in a modern synchro trans it doesn't hurt especially when two gears have bad synchros. (third and fifth)cough cough.. makes the cluthe last longer on the big trucks/semis cause they don't have synchros in their trans for durability reasons
