clutch pedal help???
i recently did a motor swap an now when get on it, at high speeds my clutch pedal will stay to the floor an i cant shift into 4th. an in order for it to work again i have to put it in nuetral an pull the pedal up an then keep pushing it in an out til it works again. What can caust this issue. it is very frustrating cause now i cant race my car at all. clutch still grips great an doesnt slip ever. thanks
I was having the same problem, but mine was with 3rd and 4th gear. My slave cyl was shot. I replaced it along with the clutch, LS7/LS2, and no more shifting problesm. This is the first time since I've owned the car(2+ years) I've been able to full on race without having some sort of shifting issue
