Need input on Monster stg 3
I would like all info you all got? Is there any issues with shimming and things need to look for? Has there been any issues with factory blemishes ! What is your first impression of it ! Compare to what other clutch ( i have textraila z grip now) !
As far as feedback, I'll let the customers that have them in their cars let you know so I'm not being too biased.
I also encourage you to look on LS1GTO.com as I've sold a ton over there as well.
Let me know if there is anything I can do for you,
Steve Addison
SNL Performance/Monster Clutch Co.
817-750-2000
Been holding up great for me, if i could stop breaking third gear blocker rings i'd be all set!! Its holding up to 430+hp launches off the spray and 530+hp launches on the spray in my nearly 4000lb car. Plus Steve is the man when it comes to customer service.
Its forsure the damnist thing! I have the textraila and the tic master and i cant shift at high rpm at all . I have a new slave and everything else. Its was dragging alittle when i first got the clutch , but i did the adj master cylinder mod and that fixed that until one day out of the blue its drags at 3000 rpms know clutch in and in 1st gear . I have adjust the cylinder and bleed the **** out of it and still no better at all. What would up and just cause this . I mean i would hate to put a clutch in if i didnt need too ! But that is what i am looking at . When i hit over 4500 rpms its impossible to shift it just wont happen ! I as thinking a failure of some sort! But not sure what else to look at ?
You have a Textralia, so, I'd call Tex and see if they will take care of you or possibly tell you why their clutch is acting this way.
I always send people to the company who makes their clutch, trying to get everyone else's opinion isn't always the best thing to do, the guys who make it know it best, chances are they may have had this issue before.
