ls7 install questions...
Old May 1, 2009 | 12:35 PM
92slomaro's Avatar
Question ls7 install questions...
I have a 2002 z28 with exhaust work done and and a few other little things done with a set of drag radials out back. i want to put an ls7 zo6 clutch in it, but heard there are some things you have to cut or what not. If any one has installed one please let me know how it went together and if there were any special things to be done. thanks.
Old May 2, 2009 | 02:58 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Who ever told you something needs cut is full of ****, stay away from them.
Order the LS7 kit from one of the sponsors(Scoggin Dickey, KY Speed, Byun Speed) and it'll come with the flywheel, disk and pressure plate. I even think someone give you new bolts. It's a direct bolt in
Old May 2, 2009 | 03:01 AM
letsrunem's Avatar
No cutting, direct swap
Old May 3, 2009 | 08:11 AM
crainholio's Avatar
You have to cut the tape on the shipping box, so I guess he has a point...?
Old May 3, 2009 | 06:47 PM
Daez's Avatar
You should cut.. all car advice conversations short with that guy?
Old May 4, 2009 | 11:55 AM
ChaseSS's Avatar
you may have to cut the line to the blinker fluid to drop the tranny, depends what flat washers your running too...
Old May 4, 2009 | 02:03 PM
92slomaro's Avatar
thanks for the laughs, i thought it was a direct swap too. thanks!
Old May 9, 2009 | 10:19 PM
metalmechanic's Avatar
Hey dude, dont cut yourself
Old May 9, 2009 | 10:21 PM
crainholio's Avatar
We really should cut this out...
