6sp. fluid
Old Nov 1, 2003 | 08:39 PM
gee65's Avatar
Default 6sp. fluid
I'm changing the fluid in my 2001 6sp. What should I use?
Old Nov 1, 2003 | 08:49 PM
jmd's Avatar
jmd
GM synchromesh. You have the carbon syncro linings.
Old Nov 1, 2003 | 09:58 PM
ss rally red's Avatar
It says Dextron III on the side of the trans, that is I would recomend.
Old Nov 2, 2003 | 07:39 AM
Z06PSI's Avatar
GM Synchromesh is the best I have had experience with..... smoother shifting for sure.... expensive but worth it..
Old Nov 3, 2003 | 09:21 AM
SilverTAWS6's Avatar
I just put in GM Synchromesh and LOVE it.
Definitely better then the standard Dextron III.
Chris
Old Nov 3, 2003 | 11:28 AM
SSCamaro99_3's Avatar
Nobody seems to have an answer on GM Synchrmesh and 98-00 transmissions. I am making some calls at lunch.
Old Nov 3, 2003 | 01:19 PM
Jake99SS's Avatar
I just put the Royal Purple ATF in last week and the trans shifts beautifully. It was the first time I'd changed it in 66K miles.
Old Nov 3, 2003 | 06:39 PM
Since I work at a auto service facility I service mine every 10K(only has 19K on it now, I agree that GM syn mesh is good stuff, BUT if your trans shifts good before the swap it will shift good after using Dex. As far as the 4th gens go if your have a internal problem no alternate fluid will help in most cases, but my trans shifts like [I]butter with dextron so I am sticking with it since I change it fairly often
Old Nov 3, 2003 | 08:47 PM
trackbird's Avatar
I'm happy with my Mobile 1 ATF.
Old Nov 3, 2003 | 11:02 PM
Slowhawk's Avatar
LS1Tech Sponsor
My first change I used Royal purple and my tranny started grinding gears,after 6 months(60 1/4 passes) I blew some syncro's.
After that I use cheap Dextron 3 like Coastal.The tranny shift great now,even after another 100 1/4 passes.The M6 needs some friction for the syncro's and sliders to catch.
Old Nov 7, 2003 | 11:08 AM
Noyzee's Avatar
8 second mod
I agree with slow hawk. I used the reg cheep stuf in my stock t-56.
I now use Moble1 in the new one because the builder recomended it, other then that i woulnt have used it. They say it is to slippery for the new trannies.
