Rear Engine Combo, Audi 6spd 01e & LS1
Would a LS1 mated to a Audi 6spd manual 01e transmission, in a REAR ENGINE situation turn the correct direction? I am looking for an alternative to the overpriced porsche G50 trans, for a rear engine project. The audi trans is normally mounted to the motor in S4 and A6 cars, so it would be turned around backwards in this application. I believe the normal rotation of the audi motor is clockwise, but I havent been able to verify that.
Did you find any info?
Im building a mid engine car and wants to use ls1 with a 6 speed audi 2wd diesel gearbox.
Have you found any adaptorplates?
H/Sweden
H/Sweden
I found it myself.
http://www.kitcarchassis.com/
016, 01e, a6, application, audi, audio1etransmission, combo, corvair, engine, kitcarchasis, ls1, mid, o1e, rear, trans, transmission
