Slave problems
Old Jun 9, 2009 | 06:48 PM
adam120674's Avatar
Angry Slave problems
Pulled my tranny today and removed the slave cylinder. Put it in 3 months ago! My car had gotten hard to shift and then completely stopped shifting. Notice the slave was leaking at the seal (with so help from Ls1 tech). Replaced and bled the clutch and it looks like the same thing happening again. Am I installing this damn thing wrong ? I just slid the assembly over the spine and bolted it up, Made sure it sat flat, hooked back up the clutch line and bled. Is the spring suppose to be on the seal , because it is not, it is over it. What keeps the seal in place? Thanks for any help.
Old Jun 11, 2009 | 08:44 AM
adam120674's Avatar
OK, here is what is happening. The seal (diagram) is pushing too far out. The throw out bearing doesn't stop the seal before the fluid starts to leak from the side of the seal. Removed tranny again, pushed the throw out bearing back on and twisted it. Tried to pull off with my hand, it stayed on. Reinstalled bled and it worked, for about 30 secs, then started leaking again. I do not see any groves or anything that limits the throw out bearing from moving too far out. Any ideas on what I need to do?
Old Jun 11, 2009 | 08:47 AM
Gen414's Avatar
Have you been reusing teh same TOB this whole time? If so, it just maybe a defected TOB?
Old Jun 11, 2009 | 10:08 AM
adam120674's Avatar
no, a new on came with the slave
Old Jun 11, 2009 | 10:35 AM
Matt@SNLPerformance's Avatar
What clutch is in the car?
Old Jun 11, 2009 | 11:11 AM
Wesmanw02's Avatar
Thats what I was going to ask. Sounds like the slave is traveling too far, causing it to leak.
Old Jun 11, 2009 | 05:46 PM
Give us a call, our clutch or not we'll help you out!
Old Jun 12, 2009 | 04:31 PM
adam120674's Avatar
I have a Bully Clutch stage 3. Didn't come with a fly wheel, is their flywheel thicker? Strange thing is it worked fine for 3 months then started giving me hell.
Old Jun 13, 2009 | 07:20 AM
adam120674's Avatar
I think I can just shim it and it would be fine. Does anyone know if someone sells just the shims without the clutch?
Old Jun 13, 2009 | 07:37 AM
Gen414's Avatar
Check with Tick, I am sure they have plenty of shims floating around. I believe that you are heading in the right direction, since you swapped TOB's, and the problem is STILL there
Old Jun 13, 2009 | 09:32 PM
brad8266's Avatar
I think spec will sell the shim as well.
