Clutch wont Bleed - Need Help...
Okay... here's where I'm at... I have a 1998 Z28 with 6 speed - New Spec 2 plus clutch [yes, the shim is installed] - new slave, new friction plate on Fidanza Flywheel - New Clutch Master [not adjustable]. Clutch has been bleed many, many, many, many, times [Even pulled the master off the vehicle and bench bleed it with the old slave]. No matter what I do, the clutch engages right off the floor and there is SO LITTLE pedal that the transmission wont shift without pumping the clutch several times and reverse is almost out of the question.
I have never had this problem before. I cannot find any leaks or blockages in the lines either. Anyone have any ideas? Any advise or help would be greatly appreciated.
Thanks in advance...
