5th Gear Syncro?
Old 06-16-2009, 01:04 PM
puggerton03's Avatar
Default 5th Gear Syncro?
Lately while driving my car when downshifting from 6th gear to 5th it is VERY hard to get into fifth. But shifting through the gears 1-2-3-4-5-6 I have no problems. Even downshifting all the other gears its fine, just 6th to 5th. Car is an 02 Z28 with 57,000 miles on it. Has a Pro 5.0 shifter with a short stick.
Old 06-16-2009, 01:41 PM
85MikeTPI's Avatar
Synchro most likely.. Upshifting 4->5 you have a 25% reduction in RPMs, but downshifting from 6->5 you have a 50% increase in RPMs.
Is the clutch stock (57K miles)? A slipping clutch will also start to show in the higher gears where the most engine/clutch load occurs.. Try a WOT punch in 5th or 6th and see if the RPMs climb faster than they should..
Old 06-16-2009, 03:12 PM
alright thanks. it is a stock clutch as far as i know.
Old 06-17-2009, 10:31 AM
is there anything i can do to this to make it better or is my tranny slowly starting to take a ****. i dont even drive the car that hard.
Old 06-17-2009, 10:46 AM
85MikeTPI's Avatar
If it's the clutch, it will just worse as it wears. Have you ever changed the fluid in the Trans? A fresh fill of DexIII ATF might help if the synchros are worn. You can (and should) rev-match downshifts to help also..
Old 06-17-2009, 10:52 AM
Quik Sand's Avatar
+1 to testing it at WOT in the higher gears.
Old 06-17-2009, 11:19 AM
fluid only has about 6-7000 miles on it. ill try the wot in a higher gear and see if i can get it to slip. thanks.
Quick Reply: 5th Gear Syncro?
