Clutch sticks to the floor
99 camaro z28. Clutch sticks to the floor. It has to be pulled up manually with foot behind the pedal? Suggestions please?
It's most likely going to be the master or slave cylinders. This happened to me a few weeks ago. You can start by checking the clutch fluid and try bleeding the hydraulics. If this doesn't fix the problem you should try replacing one or both cylinders. I have asked and searched and I don't think there is a sure fire way to diagnose which is the problem without pulling them off the car anyway. The master cylinder should be the easiest and you can get nice adjustable replacements so I think I'll start there but I feel it's probably my slave which you need to pull tranny to access.
it has happeen to me 2 different times and I changed my clutch both times. The first time it was after I did heads and cam. The second time it did it was after I kill the pressure plate at the track. It worked fine driving it normal, but would stick when I would race. First clutch I put in was a ls7 that lasted 30k and now I am running a zoom d2.
