Is this the Master Cylinder or something else?
I've asked this question before (without as much detail) and almost everybody said master cylinder, but I needed to double check before I replace something that may not fix the problem.
If it is the master cylinder, could the problem be fixed by doing the "drill mod" I've read about?
If it's not the master, then what else could it be?
And/Or what are some less expensive options that might fix the problem for now (check/replace the hydraulic fluid, etc.)?
Thanks again for the help guys,
Ryan
I'll give the drill mod a shot and I'll probably drain the fluid and put in a some good new stuff.
This sound like a good place to start with everybody else?
