Reverse lockout solenoid. How does it work??
Good info on this link.
http://www.ls2.com/boggs/torques/enginetorques.htm
The pcm does supply the ground, and it grounds the circuit based on vehicle speed. I believe it grounds the lockout solenoid at speeds of 5 mph or below.
If that's only how the 1999 and up stuff works then I'm going to have to install a Manual Switch for myself, it'll be easier then all that wiring for the Switch on the Clutch Petal.
Reverse Inhibit Description and Operation
The reverse inhibit solenoid is a safety feature which prevents an inadvertent shift into reverse at speeds above 5 km/h (3 mph) . The system consists of the following components:
The Powertrain Control Module (PCM) .
The reverse inhibit solenoid.
With the ignition ON battery voltage is supplied directly to the reverse inhibit solenoid. At forward speeds above 5 km/h (3 mph) the PCM grounds the control circuit of the reverse inhibit solenoid. This energizes the solenoid and mechanically blocks the shift lever from going into the REVERSE position.
And heres the wiring diagram:
This is the way the 98's function as well as the old LT1 stuff also...
Won't know till I try it I guess.
I run a wire from the solenoid to a switch.
1st I had a switch on top of the shift ****- those ***** were a bit cheesy, so I switched to one in the ash tray.
The solenoid is right near the shift gate,so a wire to the console area is easy.
You can break through the gate by using some oomph, but that is a when all else fails fall back.
YOU DO have to remember to turn the switch off. It will drain your battery if you leave it on.... plus you can fetch the wrong gear when in a hurry ;-(
Didn't realize the 1998s are so different.
The 1998 still has a Reverse Inhibit Solenoid Control it's just in a different location.
It's located on block section C1 pin 42 LT/GRN wire.
It does the same thing at a different location.
Where is the cruise control inhibit or enable pin on the 1998 PCM pinout ( don't see it ) ?
You only need to connect a switch from ground to the reverse lockout somehow ?
From what I figure and seen that switch is for the Cruise dis-engage, and to help do something with the Idle when you push in the Clutch. It controls 2 seperate circuits with the 4 wires that go into it..two of the go to the Cruise Circuit, the other two send a ground signal to the PCM (Blue #32, gray wire) to let it know that the Clutch is pushed in..I beleive that is the part that helps with the idle.
I don't have it on mine and I've had no problems so far. I just got it tuned for the T56 setup, so once I get it back together I'll be able to see how it works, but I think the Reverse Lockout should function without a problem cause that goes just off of speed like we were talking about above. Even with mine tuned as an Auto I had no idle problems so I think I will be good.
Basically that switch really isnt needed if you have a tuned Engine..it can be easily wired around.
Here's an explanation of the clutch anticipation switch I found when doing a search.
https://ls1tech.com/forums/3150589-post2.html
The clutch anticipate switch is just what it says. It lets the PCM know when your about to shift so it can flare the engine up a little between shifts. It also tells the PCM to shut off cruise control when you touch the clutch pedal. And yes pin D blk/wht wire goes to ground and the other pin C gry wire goes to the PCM connector C1 pin 32. At least on a 99 f body but it should be the same from 99 on up.
I would like to say sorry for responding to you guys with incorrect information in response to 03 BUSA's original post.
Jonathan@Tick was spot on. Great diagrams from Jonathan@Tick and you the_merv.the_merv I see you changed your Avatar. Honestly I thought your older one with the shifting was cool.
Now with Pin A and Pin B, here's what you do..
Take a look at the switch # 27 there in the diagram and find it on your Petals. Take one of the Wires and clip it about 3" away from the Connector(basically give yourself enough to splice it to another wire). Now with that one wire you clipped, run that to Pin A on the Clutch Anticipation Switch Connector and splice it in. With Pin B, splice that to the other clipped wire.
Doing this will make this a series circuit, and when you push the Clutch it will disengage the cruise, as well as if you push in the Brake too.
Refer to this edited diagram if you need to..
This is the same way I did it, except I used the single Switch on the Brake Petal, moved that over to the Clutch Petal, and re-wired the TCC Switch Connector into the Cruise disengage for the Brake Petal..works flawlessly.
I've been messing with avatars..being bored.
