Need New Trans Mount
Old Oct 2, 2009 | 01:59 AM
99Bluz28's Avatar
I wouldn't think you would a problem with that on a fairly stock motor, at least I haven't.
Old Oct 2, 2009 | 09:38 AM
Shock Hawk's Avatar
It's not just the motor. We're probably looking at shift shock. Contributing factors of shift shock are torque, mount stiffness, clutch grippiness, and tire stickiness (think slicks vs street tires).
Thus, I'm trying to balance the mounts so that they do not add any extra stress on the transmission, especially since mine's got a $2000 rebuild on it.
Old Oct 2, 2009 | 10:30 AM
the_merv's Avatar
Veteran: Air Force
I would get one that re-locates it off the Tranny then.
I just ordered this one here..
Old Oct 2, 2009 | 12:49 PM
Shock Hawk's Avatar
I'm not looking to change the suspension geometry, just the mount.
Old Oct 2, 2009 | 01:06 PM
the_merv's Avatar
Veteran: Air Force
K. I was just explaining the benefit of that.
Old Oct 2, 2009 | 03:03 PM
jmd's Avatar
jmd
Thumbs up
You also indicated a concern about stress to the tailhousing of the transmission.
F-bodies with tq. arms attached like stock tend to break stock rubber trans. mounts and break tailhousings.
Cars that don't, don't.
Re-read Merv's post and take heed. I'm not saying you need to do it now to replace a broken mount. But look what you just did to the stock mount. Divorcing the tq. arm from the tail. is how to prevent that from happening anywhere near as much.
Old Oct 2, 2009 | 11:01 PM
Shock Hawk's Avatar
Yes, I did break the mount, but it is the original mount and I've been racing the car, so I expect it to break. I'm also expecting to be able to get one outside of GM.
Back to my last question. Can I use the V6 A4 mount?
Old Oct 2, 2009 | 11:17 PM
the_merv's Avatar
Veteran: Air Force
Yes, the V6 one is the same.
Old Oct 3, 2009 | 12:09 AM
Shock Hawk's Avatar
So, basically, any F-Body mount is interchangeable with all the others?
Old Oct 3, 2009 | 09:54 AM
the_merv's Avatar
Veteran: Air Force
Pretty much.. the 4L60E(V6 or V8) and the T56(LT1 or LS1) use the same mount.
Old Oct 3, 2009 | 06:14 PM
Shock Hawk's Avatar
I wonder why, then, that Anchor doesn't list the mount for all engine/trans choices.
btw, you know this how? I just don't want to find myself under my car, realizing that the mount doesn't work.
Old Oct 3, 2009 | 08:29 PM
  #32
the_merv's Avatar
Veteran: Air Force
I know this cause I've worked on a ton of them..
Old Oct 3, 2009 | 09:23 PM
  #33
Shock Hawk's Avatar
Thanks for the info.
