Need New Trans Mount
Old Sep 26, 2009 | 10:54 AM
Shock Hawk's Avatar
Default Need New Trans Mount
Ok guys, I've got a 2000 WS6 LS1 T56 with a broken trans mount. Not only has the drivetrain shifted (gotta force it in reverse), but it rattles at idle and in reverse.
I've heard that a poly trans mount and stock rubber engine mounts can add extra stress to the trans housing during hard acceleration (365hp). Also, I've got a McLeod master cylinder with a Centerforce clutch, so I don't want to shock the 10 bolt too much, even though I've got a girdle on it.
I read an old thread that talked about using an auto mount because the stock manual mounts are oil filled or something. Suggestions?
I can't find a stock rubber mount outside of GM. However, I'm open to suggestions.
Old Sep 26, 2009 | 10:58 AM
dockSS's Avatar
is your TA still attached to your tail shaft?
Old Sep 26, 2009 | 11:37 AM
Shock Hawk's Avatar
Absolute truth... haven't looked...
Old Sep 26, 2009 | 09:54 PM
Shock Hawk's Avatar
Where can I get this stuff?
Old Sep 26, 2009 | 10:09 PM
underpressureWs6's Avatar
Pm sent!!!!!
Old Sep 26, 2009 | 10:33 PM
Shock Hawk's Avatar
Will the A4 mount fit on the M6?
Old Sep 27, 2009 | 03:05 PM
yeah its the same dimensions and size as the m6 mount
Old Sep 27, 2009 | 04:42 PM
Shock Hawk's Avatar
Would the V6 A4 mount be different from the V8 A4 mount?
Old Sep 28, 2009 | 11:17 PM
Shock Hawk's Avatar
Anyone?
Old Sep 29, 2009 | 01:48 AM
Krab's Avatar
Don't know about the 3.8L tranny mount being the same or not, but where in the world did you hear that the manual mounts are oil filled? I'd just get yourself a stock mount because a poly mount will transmit more NVH to the cabin of the vehicle.
Old Sep 29, 2009 | 08:27 AM
the_merv's Avatar
Veteran: Air Force
All of them mounts are damn near identical.
I would get the Torque Arm off of the Tranny..as in one of the Tunnel Brace mounted ones.
Old Sep 29, 2009 | 12:11 PM
Shock Hawk's Avatar
The oil filled thing is from an old post I found while searching the forums. I see that the Anchor brand 3.8L auto mounts are "hydraulic," whatever that means (oil filled?).
This thread is being made because I can't get a stock mount outside of GM for the manual as far as I can find. (not looking for poly)
Old Sep 29, 2009 | 07:32 PM
I HAVE a STOCK Rubber mount if ur interested.......
Old Sep 29, 2009 | 09:01 PM
Shock Hawk's Avatar
I understand that and it's a good deal assuming that the V6 auto mount won't work since I can get one from O'Reilly's for under $25.
Old Sep 30, 2009 | 10:19 PM
OHHHH ok, let me know lol
Old Oct 1, 2009 | 09:04 PM
99Bluz28's Avatar
Just get a ES trans mount and grind the pre-load bumps off, then install it!
Old Oct 1, 2009 | 09:39 PM
Shock Hawk's Avatar
What's an ES mount?
Old Oct 1, 2009 | 09:48 PM
the_merv's Avatar
Veteran: Air Force
Energy Suspension. Same one I have.
Old Oct 1, 2009 | 10:29 PM
slayerized6's Avatar
I believe the ES trans mount fits any RWD GM car or truck from 86 and up. atleast that what the box says
Old Oct 2, 2009 | 12:29 AM
Shock Hawk's Avatar
I've read that lots of people with rubber engine mounts and a poly trans mount break their transmission housing. This is because they have a stiffer trans mount than engine mounts.
