Please share your launching technique
Old 12-06-2003, 09:33 PM
big dave's Avatar
Default Please share your launching technique
No matter how hard I try, I just can't seem to find the sweet spot on this ls1. I've tried launching from as little as 2k, which results in bad bogging, and 4k which blows the tires off. I've gotten the hang of riding the clutch out a bit and am able to get consistent 2.0 60' times on the street tires. Problem is when I tried drag radials, I couldn't improve on those short times. I tried going up to 4500 rpms and it only bogged the motor. I'm not willing to go to 5500 on the stock rear. What am I doing wrong? What else can I do?
Old 12-07-2003, 11:11 AM
10 Second Club + 14 Second Truck Club
antz01ta's Avatar
get 15" et-streets, heat em up, take it to 6000, sidestep the clutch and hope the rear stays together.
thats what i do, but it's on a 12 bolt.
Old 12-10-2003, 03:36 PM
T-maxx's Avatar
1.6 60ft. Why didn't I spend the money for a 12 bolt yet
Old 12-10-2003, 06:35 PM
goodhands's Avatar
Keep working with the BFG's. Try raising the psi until you break the tires loose at 4500 rpm
Old 12-11-2003, 12:05 AM
fastsspr's Avatar
I don't know but if you still have the factory aluminum driveshaft,when you hook with drag radials @ 4500rpm.You start a savings plan for a new one...
At 4k with nittos i twisted mine in 2 pieces!!
98 red SS M6
4.10,Ls6 intake,HPP3,spect III x-pad,cut out & free mods.
Old 12-11-2003, 10:35 PM
SMOKIN01TA's Avatar
[QUOTE=fastsspr]I don't know but if you still have the factory aluminum driveshaft,when you hook with drag radials @ 4500rpm.You start a savings plan for a new one...
98 red SS M6
4.10,Ls6 intake,HPP3,spect III x-pad,cut out & free mods.[/QUOTE
the best i have done so far is 1.78 on nittos but i can do a little better with some practice. the key is to get them hot and run about 15 psi. start a 4k and get off it quick. dont side step it, just pick your foot up quick. i havent roasted them yet but plan on trying 4300 next time. i have not broke the ds yet but i just bought some streets so thats going to hurt soon.
Old 12-16-2003, 03:22 PM
antz01ta's Avatar
i'm still running the stock drive shaft.
Old 12-16-2003, 04:57 PM
2002SilverWS-6's Avatar
I've cut as low as 1.82 60' with stock rear, gear and driveshaft with drag radials. I leave around 45-5000 rpm buy dumping it and 14lbs in my BFG's.
Old 12-17-2003, 12:16 PM
Z284U2TRY's Avatar
bfg's @5000
Old 12-17-2003, 03:20 PM
black_z's Avatar
Thats HAWT.
Old 12-17-2003, 04:33 PM
JohnR's Avatar
WOW!
You need some gruntin, growlin, get-your-wimpy-***-outa-my-way, Bull dog sound effects to go along with that twisted shaft.
Old 12-20-2003, 04:15 PM
MoNkEyZQ8's Avatar
ouch..
Old 12-20-2003, 05:28 PM
HOTROD98Z's Avatar
Whoops
Old 12-21-2003, 02:58 PM
jerflash's Avatar
thats a keeper
with my nittos i do a good burn out get her up to 4000 and drop the clutch and hold on
Old 12-22-2003, 09:29 AM
Squintz Palladoris's Avatar
A gear will definately help with the bog at lower rpm. It makes the car much easier to launch. Just save your money and go with a 12 bolt or nine inch. I put a set of 4.30's in my car for a temporary fix. Made about 20 passes on nittos without any problems. On the way home from work last week I cracked 3 teeth on the ring gear. Luckily all of my nine inch stuff is paid for I am just waiting on the housing and axles to get here from billingsley.
Brad
Old 12-25-2003, 07:20 AM
99camarozboy's Avatar
On street tires I try about 3000 RPMs and I can let off fairly quick and move foward. I try below that it bogs out above that i get major spin and I gotta pedal it to get it moving. Then again I hardly drive my car.
Old 01-05-2004, 12:50 AM
MASS seller approved
Time2Kill's Avatar
I still have the stock driveshaft in my 10 second car. Cutting 1.50 60fts and launching at 6500 rpm and BARELY breaking ET Streets loose.
Old 01-05-2004, 03:27 AM
SScam68's Avatar
Just keep practing. If anything all the responses in this thread should show you each car is different.
245 555R's
Dumped at 3K will bog.
Dumped at 4K on the street will spin once, maybe twice grab and bog.
At 5k I'll lay down maybe a 10ft patch but the car is moving hard.
No track times yet, closed for winter.
Old 01-15-2004, 06:01 PM
big dave's Avatar
Do any of you guys run with your front swaybar removed or disconnected? I know it worked pretty well with my '94, which is an a4, but how well will it work with the 6spd?
Old 01-16-2004, 02:39 AM
I saw no gain.
