After my Spec 3+ Install, Engages low and creeps forward
I am about ready to install a TH350/400 at this point. I recently installed a Spec 3+ Clutch Kit and since then it is hard to get into gear, esp reverse. Strange thing is when sitting still, pusing the clutch pedal in and putting into 1st gear without releasing clutch pedal, the car creeps forward like the clutch is engaged. Same in reverse.
Also, you can forget shifting a high rpms, it's not gonna happen.
Question, some have told me a Tick Master will solve my issues, others have told me a shim will solve my issues.
Any idea's?
BTW, previous clutch was LS6 clutch, shifted great, nice engagement and all. ++++
Any idea's?
This was going to be my first question. Also, have you properly and fully bled the clutch? Basic questions, I know, but they need to be asked before anything else is considered.
BTW, I am still on my factory 2001 hydraulics.
Thanks for the response guys. No shim was sent with kit or used. Yes, I have been using sticks for years in different cars and the clutch is bled perfect. Nice firm pedal still, no sticking to floor, just VERY low clutch engagement.
If the pedal feels good and the hydraulics are bled properly, plus the master and slave checkout, you're looking at a pressure plate issue, most likely, but talk to Jeremy first. He might come up with something else to try.
I would have to agree with the posts above in that your clutch is not fully disingaging. Spec normally uses a shim with their clutches, so I would probably try to get in touch with them about getting one.
Vcious, What is the part number for the kit you installed? All of our LS1 based kits include a shim and it is located in a plastic bag with the warranty and installation notes. Perhaps this was overlooked or disgarded unintentionally. This shim is required, and should be installed behind the stock slave-cylinder. Without it the clutch engagement point will be very low. If you like you are welcome to call me at the number to discuss this further. Thanks,
For everyone else on more info, I did buy this clutch kit as "barely used" from a member here, but the seller left the shim on the transmission and did not ship it to me with the clutch (found out about 5 minutes ago). I should have asked before I bought the clutch. Lesson learned... just sucks I have to pull the trans back out because "somebody" left out an important detail/item.
+1 Appreciate the help Jeremy.
As far as you never having to use a shim, I did not either in my old 99 c5. I had a spec stage 4 ceramic disc, shifted flawless. The new Spec 3+ is a different setup all together, thats why it's comes with the shim.
I think it ultimately comes down to the somewhat extreme variance found in the cars. For instance, I have seen stock slave/bearing assemblies with as much as 1/4" difference in compressed depth. Though a 1/4" may not seem like a lot it has a tremendous impact on clutch function.
I also suspect that these bell-housings/transmissions have a decent amount of variance in total depth. I have only been under a few cars since I started measuring (previously I hadn't thought to do this) but I have seen a little more than 1/16" (.0625") difference. I know, again this may not seem like much but when you realize that clutches are affected by miniscule height changes you will understand the significance.
I will continue to take measurements and take them into account when providing info for you all in the future. Let me know if you have any further questions. Thanks,
Thanks Brad. I'm gonna start tonight. Try to have it ready for friday night. Gonna try to make a 1/4 mile pass.
It's all good JP. I appreciate to interest and help. I am with you on thinking, I have never shimmed either, but am willing to try a $5 part than a $350 MC. I'll let you know.
Thanks for the info. makes sense.
Originally Posted by TINKRD
i've got a spec3+ in my car now. drives like stock
(not giving you a hard time, but never have figured out why i've never had to shim a spec :dunno: )
