Is the mount on a F-body T56 offset?
This may or may not be a simple question but like in the title, Is the transmission mount on a F-body LS1 T-56 offset to one side or the other? It does not appear to be. I am setting my Chevelle up and am playing with the pinion angle and crossmember/header combo. Thanks
Dave
Dave
The crossmember mount is offset, but that's in relation to the frame mounts, which may be offset themselves. My xmem has 9.5" from frame bolt to trans mount bolt on the LHS, and 7.5" on the RHS..
I can't imagine it being that much of an offset needed, or any at all like you mention. But OTOH, since the Fbody's had the Torque-Arm running along the LHS, it may have required the offset for clearance...
