4th gear syncro going? Symptoms?
What are symptoms of my 4th gear syncro going bad? Usually if I try shifting hard and fast into 4th gear I get lots of grinding and it just won't go into gear. In order to go into gear, I have to ease it in slowly, just push it until it slides in.
In regular driving 4th gear also seems to be tougher to get into it and requires more effort.
Tick adjustable master, new slave, new ls7 clutch, stock tranny
Yeah, sounds like a synchro. You having any problems with any other gears, or just that one gear?
If so, then yes, synchro (engagement teeth could be jacked up on 4th as well, especially if you continue to drive it)
it is either tha syncro or it could bethe teeth it self on the gear had the same problem with a tranny i had in second thought the syncro was bad got it apart and found out it was the teeth half way gone on the gear and the syncro was fine but cheper if its just the syncro
would'nt he have an issue with 3rd as well? the syncro is the same one for 3rd and 4th gear,, or am i wrong on that....(trannynewb)
i know on mine,, EVERY NOW n THEN (when its cold or i first get the car out, and only when im driving like i stole it) i get a sound/feeling when going into 3rd/4th like there is no clutch,, i get a slight grind when going into those gears under those circumstances,,,, but it goes right in. After it warms up it has no issues at all. (in that dept )
No, not necessarily. Even though 3rd and 4th share teh same synchro, each gear has its own "side". Here is a picture of a synchro:
http://www.morrismotorsports.net/t56_parts_for_sale
Now, if a KEY was an issue, or teh fork (or fork pads), then YES, he would have a problem with 3 and 4 more than likely, since the synchro (or slider) slides on the same key when engaging 3rd or 4th, and if it was a fork, 3rd and 4th share teh same fork (and pads) so would have a problem with both gears as well if fork (or pad)
