Help with tranny removal.
Old Nov 7, 2009 | 01:19 PM
69dodgecharger's Avatar
Default Help with tranny removal.
Hey, so I am doing a auto to manual swap on a f-body. Probably the 5th one I have done. Anyways I am having an issue with this car that I have not had before. With the tranny cross member removed, TQ arm removed, driveshaft ect... the tranny only lowered about 1 1/2". Far from enough to access the bolts near the top. Looking over the car it looks to have new motor mounts, maybe poly mounts, dont know exactly as I am a vette mechanic more than an f-body mechanic. The mounts seem to be limiting the drop of the tranny.
What would be the best method of getting that tranny to drop down more?
Thanks!!!
Old Nov 8, 2009 | 09:16 PM
rabiddog's Avatar
loosen the motor mounts
alternative
big crowbar
Old Nov 8, 2009 | 10:11 PM
taws6m6's Avatar
Yeah the polys are gonna limit the movement some if they are there. Only other alternative is stated above. I would be after a big crowbar before I loosened up those mounts though
Old Nov 8, 2009 | 10:15 PM
JeaneZ28's Avatar
You should still be able to get it out. I got one out that had solid mounts.
Old Nov 8, 2009 | 10:21 PM
the_merv's Avatar
Veteran: Air Force
Leave the bottom bolts in and pull down on that mother..
Are you on a lift with it? If so take a long 2x4 and place it under the Balancer, let the lift down a lil and watch the Engine tilt back.
Old Nov 8, 2009 | 11:29 PM
haighter's Avatar
Are you trying to get the auto out or the t56? Can you not get the bolts that are on the top? I have never needed to get the trans down lower. If you need the trans down lower you can loosten the bolts that hold the k-member in. Keep the two fronts on a little and let the backs out and then let the centers out a bit while holding the back of the oil pan with a screw jack. Make sure not to place the screw jack in the center because you can crack the pan. Thats if you need to do that. I dont see why you need to. Get this tool from snapon. Works everytime. IMSFXL33 you will allways be able to get to the top bolt of an auto if you hit it from the drivers side of the trans about 3/4 the way back from the tail shaft.
Old Nov 9, 2009 | 01:21 PM
the_merv's Avatar
Veteran: Air Force
I think he's trying to yank the A4 out..
Old Nov 14, 2009 | 10:59 AM
01ssreda4's Avatar
trader.............
Old Nov 14, 2009 | 11:41 AM
the_merv's Avatar
Veteran: Air Force
Old Nov 14, 2009 | 06:34 PM
01ssreda4's Avatar
Old Nov 16, 2009 | 12:59 AM
CUR 4 VNM's Avatar
Originally Posted by 01ssreda4
trader.............
lmao thats my car he is talking about. no i got a hell of a deal on a completely rebuilt t56 and conversion parts. trust me nothing like a stalled auto. but the auto wont hold the new power.
Old Nov 16, 2009 | 08:05 AM
the_merv's Avatar
Veteran: Air Force
He's still young and hasn't expierenced the fun with the M6..
Old Nov 16, 2009 | 09:32 AM
CUR 4 VNM's Avatar
Lol....
