Spec 3 + feels good ..
Just installed my spec 3+ kit with their steel flywheel.
It feels good, Grabby but pedal feels good. Not to stiff. It has no chatter but does have a slight bounce/jerk if you let the pedal off to fast. And no more second gear starts but its ok ill live without that...
I used the spec salve that was 200$. I tried to first use a F-body slave but the fitings were totaly diffrent from the CTS-V slave. The Spec slave is identical to stock, even has the same part number stamps . The only down side is the Tick bleeder Did not fit.
And the $80 harbor fright jack was awsome, made it possible for me to do this as a one man job.. (I also found a 20% off coupon online when I bought mine ...hehe) and it came in handy when I had to pull my long tubes...
Im still in break in milage but Im happy with it so far.
Check out this video of how junk the stock 49lb flywheel is
http://www.youtube.com/watch?v=zF5JeNENMUU
Fbody slave next to CTS-V slave (couldnt use the f-body slave, fitings were to diffrent.)
Stock trans mount filled with 80a urathane..
I'm glad that you are so pleased with the results! Please keep me posted and you continue to break-in and use the clutch and if you have any questions feel free to contact me. Thanks again and have a good evening!
