Were is the speed sensor located?
Old Nov 7, 2009 | 02:31 PM
maxspeed96ct's Avatar
Default Were is the speed sensor located?
I just finished my clutch install thursday.
And my speedometer isnt working..
I double checked today to make sure everything was plugged in underneath...
Any Idea and what happend?
did a pinch a wire or is there a sensor im not seeing....
Old Nov 8, 2009 | 09:15 AM
LS123's Avatar
What type of car? Is this your 05 CTSV in your sig?
Old Nov 8, 2009 | 09:49 AM
Yes Im going to assume its in the same spot as all the other T-56 cars and go from there...
Any idea on what may have happend ?
Is it possible the sensor just happend to fail ?
Old Nov 8, 2009 | 10:01 AM
85MikeTPI's Avatar
The CTSv VSS is actually on the RHS of the tailhousing, not the LHS like the Fbody units.
Old Nov 8, 2009 | 10:03 AM
taws6m6's Avatar
Its located on the drivers side of the trans, (f body) single bolt holding it in. I messed mine up one time installing a torque arm, somehow got in a bind on it and bent it, it didnt look broke at all, but my speedo wasnt working. Got a new one and fixed the problem
Old Nov 8, 2009 | 10:59 AM
k thanks , which one is it ?
the one with the two orange wires or the one just before the drivesaft ?
Old Nov 8, 2009 | 11:59 AM
85MikeTPI's Avatar
The VSS is back on the tailhousing (by driveshaft). The front sensor with the wires is the Reverse/Backup sensor.
Old Nov 8, 2009 | 01:27 PM
Thanks man..
I could of damaged in during the install or removal..
anyone know how much the sensor goes for ?
Old Nov 8, 2009 | 03:04 PM
Berto's Avatar
Thanks man..
I just bought one for my T/A T56 and it was a bit over $30 at advance auto parts!
Old Nov 10, 2009 | 08:29 PM
anyone know if I could use the camaro /vette speed sensor on my V?
Looks diffrent in the autozone pic online but that could be wrong..
