B&M "Stick Shift" gear lube?
Anyone heard anything about the B&M "Stick Shift" sythetic gear lube before? I happened to stumble across some and in my hour or so of research, I've not been able to find anything about it.
I found this somewhere on B&M's site, but that's all:
A synthetic formula engineered for racing
and performance applications, B&M Synthetic
Stick Shift allows you to get the best
performance out of your manual transmission,
transaxle or differential. Extensive testing shows
B&M Stick Shift provides total lubrication
protection for street and heavy-duty applications.
It gives outstanding oxidation stability, extreme
pressure protection, anti-shear agents and foam
inhibitors that exhibit a tenacious capability to
keep on lubricating under extreme conditions.
It provides excellent cold weather properties
and high temperature stability not found in most
gear oils. SAE 75W90 fluid allows quicker shifts,
improved fuel economy and is compatible with
other automotive gear oils. Stick Shift’s golden
color offers easy detection of even the slightest
contamination.
Is it worth a try you think? Anyone?
Just curious more than anything.
Thanks.
contamination.
Thanks.
