B&M synthetic trick shift fluid...
Hey, wanted to give a heads up on the B&M fluid being clearanced at Advance Auto. It's priced at $2.95 a quart and is a Dextron 3 fluid which makes it perfect for the T56. I find it to be a slight improvement over the mix of Mobil 1 ATF and Synchromesh I previous had in it(Synchromesh is an acceptable fluid for the T56 but maybe not the optimal one, and some love M1 ATF while others have had less than stellar results). So far I rank this the best fluid I've used which also included whatever Dextron 3 was originally put in it and Valvoline Durablend ATF.
