hydraulic throwout bearing removal-need help asap
i cannot get the stupid thing off. i tried squezzing the **** out of the plastic collar and pulling on the throwout bearin to separte, but no luck. i tried stuffing the white collar inside the bearing and that didnt work. any ideas? or a special tool i can get?
I always use a small flat blade screwdriver and push the little white collar in as far as it will go. Make sure you push it in all the way around and the line should pull free fairly easily.
