Have a question about a t56 tranny
I think im about to get a 98 ss camaro m6
car has about 104,xxx on it everything is good when up shifting up but when you start to down shift its makes like a winning sound but still goes into all the gears fine anyone know what it is???? Thanks alot for your help
Without being more specific, I would say it's one of the bearings. The gears are helical and when the load is reversed, like on a down shift, the bearing can be on its way out.
Does it make noise on ALL gears when down shifting or just few? If the noise goes away down shifting to 4th, I would say the cluster gear bearing.
I would not jump to concluding a concern with a bearing so fast.When downshifting the synchros speed up the lower gear you are selecting. When doing this a whirr type sound can be heard.It is normal to hear this synchronizer work.
It is quite possible to put an excessive speed into the clutch disc when down shifting so be careful.You are speeding the disc up by the ratio of the lower gear. If you engage the clutch at an excessive speed, following such a downshift,it is also quite possible to overspeed the engine.
mine made the whine downshifting lasted for while then it went lol ive got pics needless to say its better to get it fixed now!
to fix mine i would need
-cluster shaft.input shaft main shaft 2nd gear synchro assembly/ slider and a couple bearings
2002sscamaro, have you driven a manual before? Do you know how to rev match during a down shift? If so, then I still say it's in the bearing. If you are rev matching, I would have to agree with calhoon.
yes this is my 3rd ss camaro m6 i know how to rev match when down shifting but now the sound has stop so i don't know what the deal is but thanks for your help guys
