T56 INTERNAL GEARS HELP/ wisdom
ok got the trans apart....
main question...
are the internal gears (gear/driven gears) the same
in the t56 transmissions
from a 00 ss w/ t56..
to a 03/04 cobra t56..
gears i need are...
(1) 5th/6th synchro assy.
(2) 5th gear driven gear
(3) 5th gear speed gear
and i work at a ford dealership so i can get parts w/ discount if they are the same... please someone who KNOWS for sure shed some light...
thanks in advance
main question...
gears i need are...
thanks in advance
The 03-04 Cobra units are unique when it comes to the 5-6 area. They use a two piece cluster gear for the 5-6 gears. The Cobra has a fully spline mainshaft where these gears ride.
The F body uses a 1 piece 5-6 cluster gear that goes on the mainshaft. Half of the mainshaft is splined and the other half is press fit.
The syncro assembly and syncro rings do interchange. I would guess even with your Ford discount, any Tremec dealer can get you a better price through Tremec.
YEA i noticed the 5/6 driven gears on mine are one peice and the ford ones are 2 piece so i will order those from gm dealer...
but i will order the 5/6 synchro from ford then
cause after looking again i need...
5/6 synchro---ford
5th drive gear--gm
6th drive gear--gm
5/6 driven gear cluster--gm
correct?
5/6 synchro---ford
5th drive gear--gm
6th drive gear--gm
correct?
