Spec 3 help
I'm considering just trying the stock clutch back in it and seeing what happens now, we don't really have anything else to lose at this point...
http://www.youtube.com/watch?v=NlmoveGPMoo
EDIT: the pressure plate feels smooth although the pics look alittle rough.
Was all that I could think of 'cuz it sounds like a lifter tick. Obviously not, since it's only coming from the bell housing. Maybe there's some external projection on the outside of the pressure plate housing that catches on the inside of the bell housing or (as noted by SPEC01) something on the flywheel catching on the starter or even on the rear of the block???
You've changed the pilot bearing & the throwout bearing. So, if bearing related would be input shaft bearing on transmission. Realizing that it started only w/ clutch install, it's unlikely, but, maybe possible. Who knows, am fishin' now, really have no definate reply.
