what is this?
Old Mar 25, 2010 | 04:05 AM
Zerokube's Avatar
Default what is this?
Not my transmission but couldnt find a better photo of it but when i had my can on a lift i looked at it and it seems to be sticking out about half to 3/4 of an inch. What it is and is it supposed to stick out?
fixed sorry.
Old Mar 25, 2010 | 04:55 AM
DVS99TRANS's Avatar
Maybe a mechanical speedo. That also looks like maybe a 13 spline input so it doesn't go anywhere near my car fella
Old Mar 25, 2010 | 06:29 AM
85MikeTPI's Avatar
That's the REV backup light switch on a Mustang T5 transmission....
Old Mar 25, 2010 | 02:56 PM
Zerokube's Avatar
fixed
Old Mar 25, 2010 | 04:09 PM
araber89's Avatar
From: Holmes County (thats right Amish Country), OHIO
Looks like a Tremec transmission, but not like the T56 in my car. I have a fill plug on that side but its forward and up higher.
Old Mar 25, 2010 | 05:13 PM
raven154's Avatar
That is a Tremec T-56 and that is the fill plug. Mine doesn't stick out that far but anything is possible. The plug itself isn't very deep so it may be cross threaded if its out that far. If its tight and not leaking, I'd leave it alone.
Old Mar 25, 2010 | 05:15 PM
raven154's Avatar
Old Mar 25, 2010 | 05:22 PM
ThoR294's Avatar
wow guys really hahahaha I hope those are sarcastic posts.....
ITS THE FILL PLUG
Old Mar 25, 2010 | 05:25 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Hopefully you can read the word beside it now since the pic is friggin HUGE
Old Mar 25, 2010 | 06:31 PM
raven154's Avatar
Yeah thats what I was going for lol
Old Mar 25, 2010 | 06:46 PM
RARON455's Avatar
if you really dont know, it is the fill plug and it screws in the trans, it will stop when tight, You remove that plug and fill the trans until fluid starts to come out of that hole, Then put the plug back in.
Or it is where the flux capacitor attatches................
Old Apr 8, 2010 | 02:19 AM
Zerokube's Avatar
ok climbed underneath the car and took these, and no its not the 02 sensor wire that im talking about
far away but cant really see it
and the close up
Old Apr 8, 2010 | 02:48 AM
sxracerb25's Avatar
I could be wrong, but I believe the thing you've circled in the last post is the clutch line.
Old Apr 8, 2010 | 03:55 AM
raven154's Avatar
That is the pressure line to the slave.
