sticky pedal(tick fixed it)
just installed a new tick master cylinder, wow what a difference no more stuck pedal tranny shifts as smooth as silk, install took 35 min i used a bleeder designed for bleeding new gm power steering systems, bled perfectly the first try. so anyone trying to a fix sticky pedal tick is the answer, what a product ( great job you guys at tick).
what type of gm bleeder? will it work on my TR6060 tranny in my 2010 camaro? what is so unique about it?.. bc i thought u only need to loosen the bleeder push the clutch down, bleed and stop, then release the clutch? I never bleed a clutch before so if u have something that would make it easy to do that would be awesome. and i think mine has air in it from the first time i flushed the fluid (using rangeracceleration) technique! also i would like to use it to make flushing easier. Im descently knowledged about workin on cars just i have never messed with a clutch bleeding.
i work at a gm dealership and one of our techs bled the system for me, the device screwed on top of the master cylinder resevoir the thing works great no pumping of the clutch pedal reqiured
i saw a video of the fbody CM install and damn seems pretty damn str8 forward and simple but the GTO guys been saying it a pain
hmm maybe ill have a tech at work do it for me he said he would do it for 60
