Pops out of third gear.......
Hey guys, I'm having a problem with my 6-speed. When I'm driving slow or fast down the road in third gear, periodically the shifter will pop out. It did it on the stock shifter and I installed a Hurst shifter and it still does it. What causes this and how can I fix this problem. Thanks
Tom
Tom
Have your trannny looked at cause the same thing would happen to me in fourth and it turns out the owner before abused it heavily and the clutch was burned beyond recognition and the syncros were off. I would have a pontiac dealer take a look at before it gets worse.... Now i had to pay 2k to have the tranny replaced and a new clutch kit put in and also a new flywheel.
The problem is the 3-4 shift fork in the trans, its not going all the way into 3rd. It will probably need a new 3-4 syncro also. Its a fairly common problem, GM has a TSB on it and my 2000 did it since it was new.
Do a search on 3rd gear and you will find a lot posts about it.
Tom
Tom
Or what the other guys said
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
