Hard Shifts
Damaged/Worn Clutch Assembly (pressure plate, flywheel, friction disk)
Damaged/Worn/Leaky Clutch Master Cyl and/or Slave Cylinder
Worn/Dead Clutch Fluid
IMO you probably have driven the car with the issue or bought with the issue already there and if it was caught early it would have been fine to just replace parts or swap fluids but now your getting it in all gears more or less.
Looks like you damaged hard parts and time for a rebuild, and when you do said rebuild it will be time for new Clutch/Slave/Master and Pilot bearing.
Also I would recommend a bump from the most basic rebuilds as it replaces the majority of common issues with the T-56.
try this:
put your car in first gear with the clutch pushed in. Make sure you are on flat ground, then rev your car to 5000+rpms and hold steady. If the car wants to creep forward than its a hydraulic issue most likely and not an issue with the transmission.
Get the car on jack stands. Disconnect Line from the slave. Fill up the res and let it work down through the C/M. As you start getting a steady stream, then plug the line back in the slave.
Then proceed with a Bleed, have a friend help. DO NOT PUMP THE C/M
Make sure the Res is full as well. Have him press and hold down the clutch. You crack the bleeder loose , then tighten and have him pull the pedal up (manually if needed). Then repeat 2 more times. THEN refill res. and see if its there, if not repeat again.
that is the best way.
