New clutch won't engage Please Help!
Well, I installed my new clutch package, and now I can shift into gear once, but after that I can't engage any other gear, ( for example, I can shift into first, but if I put the clutch in and shift into neutral, I can't shift back into 1st, or any other gear). We tried bleeding the system, but I think the person manning the clutch side was sloppy about it. Here's what I've got for hardware:
Monster Stage 3 Clutch kit (w/ 18lb Flywheel and new slave)
5k mile old Master cylinder with drill mod
143k old T-56 with fresh Dex III
Any ideas? I can answer any other questions if it will help.
Well, when I say the guy on the clutch was sloppy with the bleeding, basically he just jammed his foot on the pedal about 15 or so times, didn't take any time with it at all and definitely didn't let the clutch come back up all the way with each pump. I'm going to do it myself this time, and if we're still having issues I'll definitely call.
Give us a call anyway and we'll go over any questions you may have.
Well, I've got everything in now, the clutch works, but it's almost impossible to shift into reverse. Will that be relieved by the break-in miles or is something wrong with when I put everything together?
