Where does your clutch engage in relation to pedal travel
Just a random question here for you all. I have 400 miles on my monster stage 3 break-in. I love the clutch and chatter is starting to go away also. I have noticed that my clutch engages with the pedal almost all the way up off the floor. Is this normal? I have a tick master and I assume I can adjust that down a little? I had the master before the new clutch install and didn't mess with it much afterwards since it seems to be shifting just fine.
Just looking for what everyone is experiencing. Thanks.
its normal for that to happen with a new setup. you wear in any the high spots, so the release point moves.
i take the car around the block and after the 1st few miles set the pedal to a good spot, and see if it moves agian in the next 25-100 miles and adjust as needed. did you notice it move at all in the 1st few miles
