C5 corvette torque tube input shaft run out.
Does anyone know how much run out is acceptable on the input shaft of a c5 vette torque tube? Can't seem to find the info anywhere.
Thanks!
Thanks!
The input on the prop shaft is mounted to a rubber coupler. You can grab the input and yank it really hard and move it slightly side to side. Once it is securely in the sleeve on an auto car or slid into the clutch and pilot bearing of a manual car it will be fine.
