Who likes their lightweight flywheel? I need opinions
I'm ordering a clutch today and am totally lost on whether or not to get the
lightweight flywheel or not? I've tried the search and seems like lots of
conflicting information. The car does go to the drag track occasionally..Will I
have to rev a lot more than normal to get the car going?
I just ordered a monster stage 3 with the lightweight flywheel I think its a 15?
lber and it's chromoly..so far people seem to like a lightweight flywheel
Yeah I was just looking around trying to figure out who offered the chromoly flywheels, and the lightweight flywheels from Monster are. It's only $50 more which ain't bad at all. I think you'll like it. THINK, because I've never driven one. I'll try one the next time I have to buy a new clutch.
Here ya go.. give Jason a call. He has clutch kits with light weight chromoly flywheels that he will cut you a deal on. I have his stage 3 setup and I am cutting 1.5's at the track. I did more than 10 passes that night back to back and were all consistent. Shop around for prices and then call him. His prices will not be beat and he has great feedback from members here on the board. All positive! He is a sponsor on this board.
Texas Drivetrain Performance
Fort Worth, TX 76177
Email: txdrivetrain@hotmail.com
Phone: 817-300-6840
Shop Website: http://www.texasdrivetrainperformance.com/t56.html T56 rebuilds starting at $540!
Clutch Website: www.diamondclutch.com Clutch kits starting at $369!
Phone: 817-300-6840
Give us a call if you have anymore questions.
ran 10's on the monster stage 3 with 15 lb chrome moly flywheel, no problems and consistantly went low 1.4's.... I think some people just have to get used to them. They do require a slight bit more throttle but w/e.... it's par for the course.... revs a hell of alot faster with one though!
This subject gets over-analyzed way too often & blown out of proportion. It's really a minimal difference. Most aftermarket clutches have a pressure plate that is much heavier than stock, so a light flywheel will more than make up for it. For example, my Diamond Clutch kits all weigh right around 43lbs. This is the total weight of the disc, pressure plate, and flywheel. Keep in mind that I use the 15lb lightweight chromoly flywheel with all my kits. Then I weighed a stock clutch kit and it came out to 49lbs. That is only a 12% difference in overall weight. Its just enough to feel a noticable difference. With the rotating mass being 12% lighter, the engine effeciency is increased. The advantages that you will see include; better power transfer thru the drivetrain equating to a slight gain in RWHP, RPMs climb faster, RPMs drop faster.
Disadvantages are; Less weight will give you less momentum when racing. So it will be a little more tough to get a good launch.
However, the advantage of having better engine effiency by far outweighs this disadvantage.
Considering the few trade-offs when using a lightweight flywheel, it is worth it, hands down.
have the 18lb LW from monster and i too thought it was chromoly
...i purchased mine this year too so is it billet or chromoly??? I also got mine from byunspeed which if my memory serves me correctly stated chromoly...i would like some verification.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
