Clutch visual inspection possible? Slipping etc.
Old 11-23-2010, 08:42 PM
JoeHat's Avatar
Default Clutch visual inspection possible? Slipping etc.
I have a 99Z with 95000 miles on it. My stock clutch is feeling soft,a little hard to shift and will slip if i jump on it in a higher gear at low RPM. Is the clutch history or perhaps just need a bleed job? Can it be inspected without dissassembly? Thx.
Old 11-23-2010, 09:24 PM
Grimes's Avatar
Pretty sure you will need a new clutch. 95k is a good amount of miles on a stock clutch - that's around the time mine started going. There is no way to visually check it through a port in the trans or anything. LS7 clutch is a great stock replacement.
Old 11-24-2010, 02:43 AM
cowboysfan's Avatar
sounds like you need a new clutch. sorry no window to inspect...
Old 11-24-2010, 09:35 PM
JoeHat's Avatar
Yes, feels about right, My local LS1 hotrod shop was mentioning the LS7 clutch flywheels are very heavy.Any downside to this on a basically stock LS1 car. Except for 4:10s out back? Thx.
Quick Reply: Clutch visual inspection possible? Slipping etc.
