clutch "FEEL"
To bleed LT1 hydraulics, you need to remove them from the car, hang the resevoir higher than the master, orient the master so the resevoir line is it's highest point, and then hold the slave lower than everything else.
Once you've done that, push the slave cylinder all the way in with your hand, hold it a moment, let it out, maintain the fluid level in the resevoir, and repeatedly cycle the slave until you see no more bubbles.
That said, it sucks to do that (not easy to push the slave cylinder in by hand), and for what you can get the parts for brand new, pre-bled...it's not worth the time...but you CAN do it if you're so inclined.
Since it's a sealed system, there's no reason air should ever be in the system, so you should never need to bleed the LT1 hydraulics. The only way you would have to is if you installed a replacement master from the parts store. But why do that if you can get the whole pre-bled kit, like you said.
