Twin turbo car--lightweight flywheel or not??
I currently have a 15.4lb Chromoly flywheel that needs to be surfaced...OR would a 25-30lb billet steel be better for a turbo car? (408 CID) I just firgure the heavier flywheel would help with turbo spool/launches and be better/easier to drive on the street...
I am going to be procharging my car in the next month or so. Need a clutch anyway so timing is good. What is the downside of going with a light weight flywheel? I would think it would allow engine to rev quicker. I guess they are harder to get out of the hole if your race a lot. I am no expert so I dont understand why.
boosted cars like the heavy flywheels because it keeps the motor in boost better when going through the gears without having to no lift shift, if you're going with a supercharged setup I would just go with a good quality flywheel and not really worry about weight a whole lot, im personally a fan of heavier flywheels as they tend to not break quite as often
Any other opinions or facts keep them coming for boosted cars but specifically turbo for the OP. Thanks.
Supercharger comments too if the OP doesn't mind the high jack.
