T56 with wilwood master cylinder
I read that the GM internal slave cylinder must be used with the OEM hydralic line and master cylinder. Is this true? No one sells an adaptor to convert to using an aftermarket master cylinder?
Thanks
Thanks
I'd say it's highly unlikely that anyone sells an adapter since kustom is kustom. But...
Match the bore & stroke of the stock master with an aftermarket one. Take the olde line to a shoppe that works on hydraulic lines. Get the "right" end put on the line.
I had a master cylinder end of a line added to a line with an AN -4 at the other end for a T5 master / McLeod throwout project a while back. For about 25$, they made me a line with the parts I had.
Thanks
Thanks
